Fuel pressure @ wot >
Fuel pressure @ wot
Fuel pressure @ wot
Old 06-23-2015 | 09:43 PM
Default Fuel pressure @ wot
What is the ideal fuel pressure at wot for a 509 with a holley carb? I was previously seeing 6psi at idle and 1psi at @wot. I just ordered a new fuel pump and regulator and want to make sure pressure gets set correctly
Was I losing top end only being at 1 psi?
Satisfaction is offline
Old 06-23-2015 | 09:46 PM
at 1 psi at wot it is detonating.you need 6.5 imo at wot.
mike tkach is offline
Old 06-23-2015 | 09:48 PM
SB
Yes, and probably the piston tops and ring lands too.
edit in: your oil temps where probably going real high too.
SB is offline
Old 06-23-2015 | 09:59 PM
BUP
I do not even see how you can reached WOT with 1 psi FP. The engine should be fallen on its face if this a true reading of 1 psi.
BUP is offline
Old 06-23-2015 | 10:14 PM
SB
All WOT requires is your throttle to be wide open. You can even do this with the engine off. LOL. :wink:
SB is offline
Old 06-24-2015 | 01:00 PM
Ideally your fuel system should be set up to maintain 6 psi from idle to WOT. This should not be difficult with proper line size, good fuel pump and a regulator. At 1 psi it is not able to keep up and you will run the float bowl level down and run very lean.
4mulafastech is offline
Old 06-24-2015 | 01:22 PM
I gained 6mph when I junked the Holley red pump giving me ~3psi at wot and went back to the stock mechanical unit giving me 6-7 at wot.
Baja Rooster is offline
Old 06-24-2015 | 02:49 PM
Baja, what kind of mechanical pump are you running? Regulated?
Budman II is offline
Old 06-24-2015 | 04:37 PM
Not regulated - just the stock unit that came on the 454 Mag MPI. It still keeps 6psi at wot on the 502/500hp motor.
Old 06-24-2015 | 05:49 PM
What kind of pump/regulator setup was this??
MILD THUNDER is offline
