-   -   Help with Flywheel or Ring Gear decision (https://www.offshoreonly.com/forums/general-q/327741-help-flywheel-ring-gear-decision.html)
Craney 06-25-2015 12:37 PM
Originally Posted by airjunky (Post 4322467)
Knew a guy one time that grabbed a chainfall towed his boat with unbolted motor on trailer out under a low backroads bridge slung a long tow chain around a support from underneath ,lifted it out ,pulled out then backed his truck and boat under the hanging motor in a "v" position lowered motor in bed of pickup grabbed his chain and chainfall and down the road he went .
wouldnt use a branch , fully dressed bbc is heavy
Now that's a hillbilly
Black Baja 06-25-2015 03:52 PM
I have hillbillyed many motors. Heck I picked up the back end of the boat off the trailor with the tree in my front yard.
Craney 06-25-2015 04:18 PM
I have too, a strap between 2 trees and a chain fall.
mike tkach 06-26-2015 11:04 PM
never replace a worn ring gear,just to expensive at 18 bucks.just flip it over!WTF.same bad advice as always.
Black Baja 06-27-2015 09:45 AM
What's is wrong with flipping a ring gear over? I've done it more times than I can count. With no issues. So could you please explain. Most of the time you end up with the teeth missing in one spot. Why? Because when you shut the motor off this is where it stops and has to restart in the same spot over and over again.
GPM 06-27-2015 10:06 AM
Just curious, what do you do for a living ?
Black Baja 06-27-2015 11:30 AM
Mechanic
GPM 06-27-2015 11:49 AM
What would the labor charge be to replace a ring gear ?
mike tkach 06-27-2015 10:19 PM
when the teeth get chewed up the strength of what is left is weak.it would be foolish to remove a worn ring gear and turn it over when a new one is less than 20 bucks.how do you justify to the boat owner when after 50 or so starts the ring gear broke because you reused a worn out one and now it failed.i find it hard to believe that a guy would pay 4000. for an oil pan and reuse a junk ring gear.i just don,t understand your logic.some of the things you suggest people do are just plain wrong imo.i am not being a smart azz but i just don,t understand your way of thinking!
14 apache 06-28-2015 12:22 AM
Originally Posted by Black Baja (Post 4323377)
Mechanic
Why would you want to put your reputation on the line with a come back and doing job over for nothing? Over $$$100 I would never.. This in my field also I would not chance a come back on my name,
