breaking up after 75 % throttle
i have a formula 242 with 502 / bravo , the motor runs well at lower rpms 3800 and lower but when i get into anything over that the motor feels like its surging give even more juice it will bog down . im thinking somthing with the ingnition . i changed cap rotor and plugs so im thinking coil or ignition module ? thanks in advance
I'd look at the carb,,sounds like its not delivering the fuel.,check filter behind gas line connection and take the top off carb and check for cleanliness.Then fuel pressure and after that coil and ground connections.about all I can think of.long shot,check antisyphon valve for crud clogging it up.
