Help finding Part # for rear main seal SLEEVE for GEN 6 502
I have an oil leak and going to pull the engine real quick and check the rear main seal. I want to have a sleeve kit in my hands incase I need to put a sleeve on it.
I have looked everywhere with NO luck. I know the seal is FelPro 2920.
Thanks for you help!
Speedi Sleeves ?
This may be it:
NAPA Part: NOS 99435
Crankshaft Repair Sleeve - Rear
Crankshaft Repair Sleeve I.D. : 4.3280"
Crankshaft Repair Sleeve Width : .6500"
Application Information: 1997 Chevrolet Truck K3500 1 Ton 4WD - Pickup
Engines : 7.4 L 454 CID V8
One of many applications: Chevrolet Truck C3500 1 Ton - Pickup 7.4 L 454 CID V8 1991 - 2000
Features & Benefits
Our Speedi Sleeves Repair Scored to Restored in a Few Minutes With a Few Easy Steps With No Special Tooling.; Although Installation is Simple, it Should be Done Carefully to Achieve the Best Results.; Before Starting, the Sealing Zone of the Shaft Should be Carefully Cleaned and Any Burrs or Rough Spots Should be Filed Down and Polished.; Deep Wear Grooves, Scratches or Very Rough Surfaces Should be Treated With a Suitable Powdered Metal Epoxy Filler.; The Sleeve Must be Positioned on the Shaft Before the Filler Has Hardened.; It Should Also be Noted that Although Speedi Sleeves Can be Easily Installed Within Minutes on Most Shafts.; They Should NOT Be Placed Over Splines or Keyways, etc on the Shaft.; Commonly Used on End Yokes, Input/Output Shafts, Crankshafts, Camshafts, Accessory Drive Shafts, or Wherever Needed to Alleviate Additional Costs and Downtime.; A Mallet or Rubber Hammer is Commonly Used to Drive the Sleeve on the Shaft With an Enclosed Driver Tool.; Instructions Included With Most All of Our Speedi Sleeves.; Manufactured to Meet or Exceed O.E.M. Specifications in Function, Form & Fit.
This may be it:
Features & Benefits
