Engine flooding >
Engine flooding
Engine flooding
Old 07-07-2015 | 08:47 AM
Originally Posted by BUP
Anything can happen but if you asked Holley about a backfiring to blow a power valve in their carbs they will face to face tell you no way of happening . And of course they have written it many times in their own words. I have asked them face to face and Holley says no.
Just saying and in writing plus you find this all over the net written by Holley themselves,. plus a simple test to check if so in fact you think the power valve is blown is in the story written by Holley.
http://www.enginebuildermag.com/2013...y-carburetors/
had a power valve go bad due to backfire,purchased part from holley to correct the issue,no problems since
93 shooter is offline
Old 07-07-2015 | 09:51 AM
SB
The choke linkage comes up thru the carbs air cleaner base. You sure the Flame Arrestor is not interfering with it somehow ?
SB is online now
Old 07-07-2015 | 09:56 AM
BUP
And how tall is your flame arrestor ? It might be too short. Also did you clean it very well. Hold up to the sun can you see daylight thru it ?
BUP is offline
Old 07-07-2015 | 12:28 PM
Just a quick update....motor ran good on other arrester and the just cleaned one. Going to drop it in the water today and give it the real test.
Sonichunter is offline
Old 07-07-2015 | 12:34 PM
It's the stock 500 arrestor. I could see light through it but apparently that can be deceiving. Gave it a better cleaning and although it didn't look much better to me, it's holding good idle and is responsive now. Not thoroughly confident yet but I'll run it and find out if it's a fluke or not
Old 07-10-2015 | 07:12 PM
Ok so I got to run it and the results kinda got me nervous. Started and warmed up great. Did a 3 mile run no hiccups. Shut it down to take a look and found a pool of oil sitting on the intake manifolds. Checked oil level and cleaned up the oil. I'd say it was about 1/2 a quart. Ran it again for a short distance and no oil, ran some more and no oil. Only thing I'm noticing now is a whistling at idle that comes and goes. Totally gone when put in gear. Any ideas? Only my 3rd time out with this new to me boat and I'm starting to panic
Old 07-10-2015 | 07:18 PM
SB
HP500's have PCV valves. They are just to the rear of the carb, stuck right into the intake manifold. See if this is working correctly.
#1 thru #5 in pic below.
SB is online now
Old 07-10-2015 | 07:44 PM
Thanks! Your the 3rd person to suggest that. I'll look at it in the morning when I get out of work. I'm hoping that's all it is
Old 07-10-2015 | 08:28 PM
SB
While you are there, pull out Valve (#4) and look thru grommet (#5) and see if you can see if the metal shield (#33) is there. For some reason, some people don't see the need to replace this when rebuilding or redoing top end. This valley tray keeps oil from being thrown onto the bottom of the intake. Why this is important with the HP500 and some others that have the PCV in thru the bottom of the intake, is so that oil doesn't get thrown up into the PCV. If it does, it can fill the pcv and pcv hose enough that the engine 'uses' more oil - or in this case - inhales oil. ie; oil goes back into carb and thus down intake, head, comb chamber, and etc.
SB is online now
Old 07-10-2015 | 08:48 PM
Is the pcv under the distributor cap? I'm looking at pics of my motor and I don't see it. I've tried to post a pic but can't seem to from my phone. Also I've noticed from pics of other motors that both valve covers have vent lines to the flame arrester and mine only have one, the other cover has like a small breather filter. After looking at pics of where it's supposed to be, I definitely don't have pcv valves. I'll attempt to post pics again
