motor not making the power it should be
If you have an ir temp gun shoot both blower pulleys after a run. If port pulley is way hotter than sb your belt is slipping. Aside from that, how much air is huffing out the valve cover grommet hot and idling tells a lot about an engines condition. Particularly a blower engine.
