please explain the basics of hydraulic trim tabs to a newbie >
Old 07-08-2015 | 10:55 PM
Default please explain the basics of hydraulic trim tabs to a newbie
boat is a 97 Baja 240 sport 454 carbd
boat has independently controlled hydraulic trim tabs on the back. However I don't understand how to adjust them or where to run them? Also how do I know the position of the tabs in relation to each other. The boat doesn't have a guage that shows any indication of their location in relation to UP/Down or to each other.
can somebody give me a crash course in what I should be doing here or how I should be operating these?
sorry for the newbie questions this is the first boat ive owned with trim tabs and I admit that I don't know what im doing
97240sport is offline
Old 07-08-2015 | 11:10 PM
I had the same thing on my 24 Outlaw. Bennet tabs and no indicators.
You just have to play with them and you'll get the feel of where they are at.
All down to get on plane faster and to keep the bow down. Raise them at higher speeds.
You can use them to level the boat to compensate for prop torque lean or uneven passenger loads.
Griff is offline
Old 07-09-2015 | 06:01 AM
I'm sure others will chime in, here is a little "Trim Tabs 101" I wrote.
Trim Tabs 101, How To Get The Best Results
If you are new to using Trim Tabs you may find this helpful in learning how to use them to achieve the best results. All boats react differently to Trim Tabs and the best way to find out what works best for yours is to experiment, and remember, use short bursts of the controls and let the boat settle down between corrections. Using them will soon become second nature.
Tom McGow
Bennett Marine
Getting and Staying Trimmed
All boats assume different fore to aft attitudes at different throttle settings and vary in sensitivity to lateral weight distribution.
A boat’s optimum running attitude is determined by the operator. While some people may define optimum running attitude as the highest possible speed for a given amount of engine RPMs, others desire the best possible fuel economy, yet others may be trimming the boat to get just the right mix of speed and wake (such as for waterskiing.)
Optimum running attitude is when the boat is running to the operator’s satisfaction for the given operating conditions. There are as many optimum running attitudes as there are boats and boat owners
A good way to determine a boats optimum running angle is to run the boat lightly loaded at full speed in calm water. During this test observe the boat’s bow in relation to the horizon. Most boats run at or near their optimum attitude under these conditions. This should give you a feel for the appearance of the wake and bow spray when running at an efficient attitude. Note that not all boats will achieve their optimum running attitude under these conditions. Some boats will benefit from extra lift even when running at their maximum throttle settings. If you feel the boat will benefit from added bow down trim when running at speed start with the trim tabs fully up and deflect the trim tabs in short bursts. Be alert to changes in the boats handling, as you bring the bow down. Observe any changes in RPMs and/or speed. Adjust power trim if applicable.
Indications of Running Untrimmed
When a boat is running untrimmed the bow spray will exit the sides of the boat far aft. The stern wave (wake) is high and curling like a breaker on the beach. The rooster tail is high and close to the stern. The engine is laboring and the ride tends to be less smooth.
Indications of Running Trimmed
The bow spray moves forward and is flung not as far from the boat. The wake diminishes in height, as the rooster tail flattens out and moves away from the boat. The engine is operating under less load as evidenced by the tachometer and speed as well as sounding “less strained”.
One Step at a Time
The key to obtaining optimal results from trim tabs is to operate them in short “bursts” and let the boat react before making another adjustment. The amount of time between corrections is influenced by the size of the trim tabs and the boat’s speed. This will help avoid overtrimming or ending up with one tab too far down when correcting lateral trim. You will quickly become acquainted with a boat’s particular traits.
Take Off
Properly sized trim tabs can significantly reduce the time needed to get up on plane. They also allow a boat to keep its bow down and stay on plane at lower speeds.
As the throttle is advanced the stern of the boat begins to squat, lifting the bow. As the boat accelerates, push the bow down position of the helm control in short bursts. The boat reacts by the stern lifting, the bow coming down, speed increasing, and reduced engine laboring. If you over do it and deflect the tabs too far the boat will end up overtrimmed. When over trimmed, the steering becomes “over sensitive” and wants to pull off course to port or starboard. If this occurs, operate the control “bow up" until the desired attitude is established.
Getting the Most from Power Trim
Adjust the trim tabs to achieve the desired running attitude. Then use the power trim to position the propeller thrust parallel to the water flow. If necessary, re-adjust the trim tabs to fine tune the attitude. By observing the boat’s speed and engine RPMs the best combination of trim tabs and power trim will be apparent. Trim tab angle indicators and a power trim angle indicator are particularly useful in duplicating effective settings.
Trimming to Sea Conditions
When running into a head sea you want to trim the bow down so the sharp forward sections of the boat do their work cleaving the waves. This provides the most comfortable ride and minimizes stress on the boat (and passengers). In a following sea the tabs should be fully retracted for maximum steering response.
Correction of a List
The normal control setup for trim tabs operates in relation to the desired changes in trim and not the actual movement of the tabs. Therefore, do not think about what the tabs are doing, but rather on the control and what you want the boat to do. As above, make the corrections in bursts and allow the boat to settle to the new settings. You may find it easier to correct the boat’s fore and aft attitude before you correct the side to side trim.
Correction of Porpoising
Operate the tabs in very short bursts of about half a second. Continue until porpoising subsides. The objective is to have only a very slight amount of tab deflection, just the amount needed to cure the up and down motion of the bow.
Tabman is offline
Old 07-09-2015 | 07:13 AM
VoodooRob's Avatar
My first boat had the same situation. Ordered an LED Bennet trim tab indicator and it was one of the best things I did.
VoodooRob is offline
Old 07-09-2015 | 07:38 AM
I don't know how you can effectively use your tabs without a gauge.
I did the same thing VooDo Rob did and it was money well spent.
Ken
minxguy is offline
Old 07-09-2015 | 11:42 AM
Tabman... what a great write up thanks thats just what i needed
Voodoo.... can you post a link to the trim tab gauge that i need ? Where is best place to order and is it hard to install ? Thanks
Old 07-09-2015 | 11:57 AM
Ken
Feel
endeavor1 is offline
Old 07-09-2015 | 12:19 PM
VoodooRob's Avatar
Here you go, best money spent. You should be looking at gauges and feeling women, not the boat.
http://www.bennetttrimtabs.com/produ...r-control-kit/
[ATTACH=CONFIG]542911[/ATTACH]
Assuming you have Bennett sport tabs, usually Bajas do.
Old 07-09-2015 | 09:41 PM
Voodoo
Where is the best place to order these ? Im an automotive guy just now getting into the boating world..... is there a summit racing for the marine industry? Or a board vender with good deals ?
Old 07-10-2015 | 01:19 AM
CP Performance is probably as close to a Summit as you can get.
Griff is offline
