Need help getting on plane >
Old 07-13-2015 | 10:01 AM
You should have a 1.65 ratio drive from the factory. These boats are veryyyyyyy slow to get on plane. Drive tucked all the way down and tabs all the way down and lots of throttle is what you need. .My 271 is now 715hp and I have 280 tabs and it is still slow to get on plane compared to others. What you are experiencing is normal for these boats. The correct prop for the boat should be a 26 pitch 4 blade with the 1.65 drive ratio . Jeff Wurl
jwurl is offline
Old 07-13-2015 | 12:55 PM
If it has a 1.65 drive then a 26 is probably the right prop. But a dinged up prop, full fuel and lots of gear will change planing time a LOT.
Griff is offline
Old 07-13-2015 | 01:27 PM
26" still seems like a TON of prop for that boat, what was the stock prop?? -- a guy I boat with has this boat, it runs 57-58mph, I think everything is stock.
Seems like a 24", espeically with a 4-blade would be better. If the stock prop was a 26", that will show what I know Either way, start with whatever stock was. 3-Blade will help get you some RPM's on launch if you are getting to much bite.
BBCLiberator is offline
Old 07-13-2015 | 01:34 PM
What Jeff said. I had a 271 with 635hp 1.5 drive 26P Bravo one. Didn't worry about jumping on plane. Idle out push throttle slow to 3000 rpm and wait for it to lay over. Then GO!!!.
Rattlesnake Jake is offline
