Power trim pump was running under water, replace motor or complete unit?? >
Old 07-10-2015 | 03:02 PM
Question Power trim pump was running under water, replace motor or complete unit??
Bilge pump broke, and center hull had water in it for about a month.
Trim in mounted below motor, so the trim was under water. Trim stopped working (up and down, but I could Cleary hear the solenoids working) Took trim motor off, rusty water came out. Motor lost all 4 screws (not in the bilge area) motor turns very poorly, and does not run (no surprise, that's for sure)
So my question is replace the entire pump and solenoids, or just the electric motor?
2Slow4me is offline
Old 07-11-2015 | 01:43 AM
IMO, Replace it all.
Griff is offline
Old 07-22-2015 | 11:00 AM
You can buy the motor on ebay for 60-70 bucks. But if the solenoids got wet I'd replace those too as its only a matter of time before they go. You can get those on ebay as well. I purchased the prewired bracket for $129 and the motor for $65. reused the pump and reservoir bottle.
Bracket: http://bpi.ebasicpower.com/p/PH200-T065-K
Complete: http://bpi.ebasicpower.com/p/PH200-T016-K
Motor: http://www.ebay.com/itm/TILT-TRIM-MO...item43c779172e
Solenoid: http://www.ebay.com/itm/New-TRIM-SOL...item33a0d8b5de
ivanfuego is offline
