corsa captains  call solenoid? >
Old 07-11-2015 | 11:07 PM
26sonic's Avatar
Default corsa captains call solenoid?
one of my captains call corsa exhaust solenoids on my 2002 496ho went bad who has a replacement heard that the 4wire solenoids are no longer available this is the one i need!!!
26sonic is offline
Old 07-12-2015 | 07:50 AM
Yes the 4 wire is no longer made. You might find someone with one on ebay, but my guess is it will be used. You can get a new 3 wire from Corsa and adapt it to the 4 wire system. I discussed this with them a few years ago, but in the end just bought the complete 3 wire setup and installed
AllDodge is offline
Old 04-02-2019 | 05:33 AM
Default i see 4-wire solonoids brand new so i guess they started manufacturing them again..
i have a question about the solonoid itself..
is the “rod/shaft” of soloid supposed to come out when not powered? one of the sides i can pop out.
also at the end of the “rod/shaft” of solonoid, there’s a square piece that connects to linkage on the exhaust flaps. i’m not seeing any solonoids with this square piece on the ends..is this piece removable? thank you!
amplifyd131@aol.com is offline
