Possible oil pump gears binding with a Melling 10778?  Has is happened to other? >
Old 07-16-2015 | 10:34 PM
phughes69's Avatar
Mike, this is how I clamped the pump into the vise. I actually clamped an aluminum bar into the vise, Then I used some square stock to block the outlet of the pump and used a C clamp to hold it all together on the aluminum bar. I didn't have the bolt hole completely covered with the bottom jaw of the C clamp and the oil was able to come out the bottom of the bolt hole. I was able to hang the pump in a cut jug of oil and spin it with a drill to build pressure and speed. It worked out pretty well And I was able to verify the operation of the pump at a high spreed before bolting it into the engine. If I were to do it again, I would make a dedicated block off plate for the top and bottom with an adjustable discharge valve and a pressure gauge.
[ATTACH=CONFIG]543159[/ATTACH][ATTACH=CONFIG]543160[/ATTACH][ATTACH=CONFIG]543161[/ATTACH][ATTACH=CONFIG]543162[/ATTACH]
Attached Thumbnails Possible oil pump gears binding with a Melling 10778?  Has is happened to other?-picture-004.jpg   Possible oil pump gears binding with a Melling 10778?  Has is happened to other?-picture-001.jpg   Possible oil pump gears binding with a Melling 10778?  Has is happened to other?-picture-002.jpg
Possible oil pump gears binding with a Melling 10778?  Has is happened to other?-picture-003.jpg
phughes69 is offline
Old 07-16-2015 | 10:59 PM
i have an oil pump dyno i use to test pump operation.i cant remember who makes it but i will look it up tomorrow and post it.it was only around 100 bucks and is a nice tool.
mike tkach is offline
