91-2013 fountain 29 help
A guy from my area has a 91 fountain 29ft. Has twin big blocks. 509ci or 540. I can't remember exactly. The boat was redone in 2013. Says it's around 600-650 hp per motor. What's this boat capable of with the setup. Also can you guys give me some advice of where to start bargaining. Thank you in advance.
As I unfortunately learned the hard way.... GET A SURVEY!
Originally Posted by Diamond Dave
(Post 4330608)
Hey guys thanks for the heads up. I got ahold of him. Boat has imco boxes. And the motors are 509's 650hp.
I can tell you this, friend of mine had a 98 with twin 454efi's was a great 70mph boat, ok 75mph, but when got near 80 would get scary at any time, fountain pulled the 502 twin option 1st, then the big block all together before the end of the run...tells you something. I know some guys run big power in these and get away with it...but just warning you now
Originally Posted by ezstriper
(Post 4330893)
My .02......Unless you are somehow limited to size, why not get a longer boat?
I'm just curious. I got a great deal on my Baja. And was thinking about going with something a bit bigger and faster. I figured that 29ft with those motors and drive would be around 90 mph ? I'm new to this so correct me if I'm wrong. But from what I gather the fountain boats are the ones you want as far as speed goes ? ( to an extent obviously). So seeing how this boat isn't far away I just thought maybe it would be the right choice. What are some other good suggestions ?
Originally Posted by Bajadave04
(Post 4331041)
Superboat, Activator, Kryptonite, Phantom are boats I like. Might be too bare bones to others. |
(Post 4331041)
| All times are GMT -5. The time now is 02:51 PM. |
