500efi alternater >
500efi alternater
500efi alternater
Old 08-11-2015 | 12:02 AM
Default 500efi alternater
keep burning them up due to the 2 large amps for the stereo... I think. anyone rebuild these to put out more than 70a. do they make a heavy duty replacement?
ltl driver is offline
Old 08-11-2015 | 01:16 AM
How many batteries are you running???
Griff is offline
Old 08-11-2015 | 06:41 AM
A 1 wire 100 amp Delco will bolt right in place of those factory junk Mando alternators. Haven't killed one since I switched over. I run 3 batteries and two amps.
Gimme Fuel is offline
Old 08-11-2015 | 08:06 AM
Got a part number?
Cole2534 is offline
Old 08-11-2015 | 08:28 AM
me too, 2 amps and 3 batteries. do you have a picture or part number? there are 3 different ones..70's to 88, 88 to mid 90's and 90's to present I think
Old 08-11-2015 | 08:29 AM
If you go up in amps, make sure to increase the size of the charging wire AND ground wire. The stock ones are 10 gauge, and running 100 amps through them won't work for long.
apollard is offline
Old 08-11-2015 | 08:33 AM
http://www.dbelectrical.com/p-3609-n...FRAxaQodIK4OMQ
http://www.ebay.com/itm/like/3804476...lpid=82&chn=ps
I had a local guy build mine a few years back. All brand new parts and was $100 from him. Had him rebuild one for a friend and it only costs $40 for all new internals. The marine spark arrested housing is the expensive part.
Old 08-12-2015 | 07:35 AM
thank you!!
