intake manifold heigh
Sooo I want some more power out of my 509, I'm thinking heads and intake, but want to make sure I have the physical room.
How does the MPI intake setup compare in height to a single plane manifold, carb/throttle body, and air filter? Also, what about an elbow?
I hope you have more room than I do, the little box the mefi is in already rubs the hatch, and I have maybe 2 inches above the intake because they made a place for a cutout there.
How's.the new motor running?
I have a Dart intake, holley carb, and 4" flame arrestor here at work. Also a 502MPI set up at home. I'll try to remember to measure the two and post up. I do have brain clearing events on my ride back home after work, so don't get mad if I forget.
I went from a stock 502 mpi with stainless marine exhaust to 540 ( same block ) with AFR raised port with cmi headers and the exhaust lined up fine, so I wouldn't be to concerned
I had custom tails made and they already kiss my hatch. :/
Buck, engine runs like a top. Smith did a great build and Ben Bowman did a great tune. The exhaust rumble under that platform gets a lot of looks.
That said, I'd still like to install a modern intake and throttle body. I think there would be some gains there. Plus I want to dabble with assembling some EFI stuff because I'm a nerd like that.
