Fountain won't plane out all of sudden >
Old 08-17-2015 | 02:03 AM
Default Fountain won't plane out all of sudden
After being out over the weekend I tired to plane out at the end of the day with no success. It seems like it flat doesn't have the power, it won't get above 2k rpms. I checked the following, nothing in the prop, both trim tabs work (and we're all the way down) and outdrive was all the in. Engine idles and sounds like it normally has. I even checked the bilge thinking maybe it took on water and had to much weight, none! Like I said, happened kinda all of sudden. Ran great all weekend, anchored out for about 3 hours and then no power. Any ideas out there?
cong95 is offline
Old 08-17-2015 | 05:32 AM
what engine does the boat have?
mike tkach is offline
Old 08-17-2015 | 06:34 AM
If anything spun I'd imagine he would have higher than 2k rpms. Bad fuel filter?
Unlimited jd is offline
Old 08-17-2015 | 09:30 AM
Cash Bar's Avatar
Mod Squad Enforcer
Put it in neutral and see if it revs high. If it does fine in neutral its most likely the safety switch wire(s).
www.gregsellswaterfront.com
Cash Bar is offline
Old 08-17-2015 | 09:47 AM
Knot 4 Me's Avatar
Is it backfiring, cutting out, etc? I'd suspect fuel pressure.
Knot 4 Me is offline
Old 08-17-2015 | 10:00 AM
F-2 Speedy's Avatar
If its EFI, sounds like guardian mode, like asked above ^^^ need to know what engine
F-2 Speedy is offline
Old 08-17-2015 | 10:07 AM
It's the 502 mag fuel injected. I know it's not the prop as it's a solid hub.
cong95 is offline
Old 08-17-2015 | 02:48 PM
Replace the fuel filter / water separator if you haven't in a while. Sounds like it could be a fuel pressure related problem...could be vapor locked as you said you anchored for 3 hours and then tried to get on plane...seems about the time frame people say vapor lock happens per what ive read here.
TooLateVTEC is offline
Old 08-17-2015 | 03:27 PM
Same here.
Cole2534 is offline
Old 08-17-2015 | 03:57 PM
Might also be getting a knock signal
AllDodge is offline
