Best way to attach Merc cables to a Demon Carb >
Old 08-17-2015 | 12:24 PM
Default Best way to attach Merc cables to a Demon Carb
Trying to clean up some of my rigging and need to find an adapter to attach a Merc throttle cable to the throttle arm on a demon. As of now I have a bushing in the big hole on the throttle arm but would like to use the smaller hole because the setup I have now is sloppy feeling.
87MagnumII is offline
Old 08-17-2015 | 01:01 PM
http://www.cpperformance.com/c-215-t...-brackets.aspx
Griff is offline
Old 08-17-2015 | 01:22 PM
Is that for the adjustment barrel or for the cable end?
Old 08-18-2015 | 01:28 AM
There are a couple different ways to do it depending on what parts you have or want to use.
Hover over the small images for each part and you'll see how they are used.
Griff is offline
