Question for those that have changed plugs on 496 MAG or MAG HO >
Old 08-24-2015 | 12:21 PM
BUP
maybe some tips could help whomever in this post
http://www.offshoreonly.com/forums/f...ny-tricks.html
the exercise mats work very well sitting on top of the engines to lay across. I buy them for 10 bucks and cut to fit
BUP is offline
Old 08-28-2015 | 08:18 AM
Knot 4 Me's Avatar
Originally Posted by buck35
Can you access the clamps that hold the lines in place? Then loosen the oil line and reposition it slightly to gain some space.
This is what I ended up doing. Removed the bolt on the oil line clamp on the back of the exhaust manifold and gently pried the oil line backwards to gain the clearance I needed to get to #7. Also had to remove the exhaust manifold water line to get at #3. Now that I know exactly what I need and how to access each plug, along with having dielectric grease on all the plug boots to make them easier to pull, I can do the job in about a third of the time it took the first time. Got a nice welt on my head from supporting my weight with it against the exhaust hose!
Knot 4 Me is offline
Old 08-28-2015 | 11:37 AM
Glad that worked, sometimes two steps back is the fastest way forward.
buck35 is offline
