Carburetor talk. >
Carburetor talk.
Carburetor talk.
Old 08-28-2015 | 07:58 AM
bcfountain's Avatar
Registered User
great reading mild.one thing to remember.carbs have been around for a very long time.the holley carb is one of the simplest one s to work on and reliable.i feel good about being able to fix my carb when it breaks or gets out of tune.the efi guys can look down on me all they want.i got a product that works and has been time proven.
bcfountain is offline
Going rich at high RPM might have nothing to do with jetting but could be acc. pump pull over.
fbc25el is offline
Old 08-28-2015 | 08:17 AM
is extremely easy starting an indicator of anything on a carbed motor? Does it reflect the tuning at all?
stimleck is offline
Old 08-28-2015 | 08:19 AM
SB
Idle circuit tuning.
Heated intake helps. Most of us don't have heated intakes though.
Initial ignition advance setting is just as important as the carb tuning itself.
SB is offline
Old 08-28-2015 | 08:20 AM
SB
Ooops. Double post.
SB is offline
Old 08-28-2015 | 08:51 AM
I like to "Lock Out" the timing..meaning ZERO mechanical advance. Put an MSD Start retard on if you do this! Smooth out the idle a bunch!
TAStevens is offline
Old 08-28-2015 | 06:53 PM
Yes, Really helps when you are running a long duration camshaft. Thats one of the nice thing about some of the new programmable ignitions from Daytona sensors, msd, etc. You can have lots of timing at idle, bring it back once off idle, then bring it back in gradually, or quickly, or based on a map sensor value, etc. Locked timing is cool for idling, but on certain setups, can really cause issues.
MILD THUNDER is offline
Old 08-28-2015 | 07:45 PM
KAAMA's Avatar
Originally Posted by SB
All depends on booster design (annulars will start sooner), throttle bore + venturi size, air bleed size, and throttle opening. vs the airflow which is determined obviously by engine cid, camshaft, cyl head, intake manifold, throttle opening , exhaust and etc.
On the same engine, A smaller throttle bore/venturi carb with annular boosters and smaller air bleed will start flowing fuel a ton quicker than a huge bore/venturi with larger bleeds and say a dog leg booster.
Yeah, I kinda like the idea of the AD Boosters too! Looks like Holley doesn't offer an Annular Discharge Booster for their Ultra XP series carbs.....bummer. We're about to order my Holley carbs. We plan on using the Holley Ultra XP carbs (950cfm).
Anyway, I enjoyed the read guys.
KAAMA is offline
Old 08-28-2015 | 07:54 PM
Full Force's Avatar
I still need to get in and closer tune mine, waiting for Mild to make a trip to Ohio and help... lol I been just running and enjoying the boat he last 4-5 weeks, after Labor Day I will start tuning again and beating it more...
Full Force is offline
Old 08-29-2015 | 12:24 AM
So what wideband do you use?
BBCLiberator is offline
