WHELP, time for a new motor/rebuild...Recommendations???? >
Old 08-29-2015, 01:29 PM
Just send it to Eddie Young and tell what hp you want.
Padraig
Padraig is offline
Old 08-29-2015, 08:15 PM
Before you get too carried away, check out the heads. If I remember from a previous thread, the last owner was pretty good about maintenance so make sure that a small thing is not causing you big grief.
buck35 is offline
Old 10-08-2015, 10:47 AM
So what'd ya do?
Cole2534 is offline
Old 10-08-2015, 11:27 AM
Originally Posted by airjunky
Do a leakdown then teardown. Then you will really know what your working with
What he said!
I had low compression numbers too. 60 and 80 in two different cylinders. Turned out to be ad exhaust valves which I would say is your case if you had header leaks. There was nothing wrong with my bottom end, short block and piston rings were perfect!
Just get the heads re-done. No since in tearing down a good running short block. Most black motors are good for 800 or more hrs with regular oil changes.
Rambocj7 is offline
Old 10-14-2015, 01:19 PM
Went with pulling the motor. Having everything disassembled and checked to figure out what I HAVE to spend. Hopefully, after buying what I have to I'll money left in the budget for some extras...fingers crossed!
cong95 is offline
Old 10-14-2015, 06:53 PM
Sounds very familiar... lol
Diamond Dave is offline
