sea water / fuel pump rebuild........help >
Old 08-28-2015 | 03:18 PM
Default sea water / fuel pump rebuild........help
Does anyone have the link detailing the rebuilding of the pump to include the shaft, bearings etc. I don't need the link for impeller replacement. All my recent engine issues are discovered, the cam and ring on the pump shaft are damaged and I need to do a complete rebuild.
Thanks,
ed
Interceptor is offline
Old 08-28-2015 | 03:37 PM
Nothing special about it except you'll need the tool to remove the pulley, auto parts store will have that for rent.
Press the old stuff out, order replacements, press new stuff in.
I walked into a bearing house with the old components and walked out with new for $20ish.
As for the shaft, I dunno. Lol
Cole2534 is offline
Old 08-28-2015 | 04:08 PM
I found the thread. I need the shaft and cam ring so it is a mercruiser only parts. Ordering from BAM.
Old 08-28-2015 | 04:48 PM
I'd replace the seals as well. If those lose integrity you'll be really upset with yourself.
Cole2534 is offline
Old 08-29-2015 | 12:08 AM
Dumb question, when I just took my fuel pump off I noticed a plastic bushing floating loose on the cam? Does that make any sense? Should it be that way? I did a search and asked a few questions but couldn't get an answer.
Baja Rooster is offline
Old 08-29-2015 | 08:28 AM
There should be a metal ring.
Old 08-29-2015 | 09:13 AM
Just did this myself. Luckily, me shaft and collar were OK. I have another pump I replaced years ago with a whole new assembly, due to a bad shaft that was grooved at a seal location. Was not aware that the shaft was still available?
Cory H is offline
Old 08-29-2015 | 10:19 AM
Shaft is part of a kit per mercruiserparts.com
Old 08-29-2015 | 11:41 AM
I kinda remember it being teflon, but I could be mistaken. It just loosely floats around the cam lobe, correct? The box of parts that came with the boat had an old fuel pump in it where the arm was worn nearly completely through so it had been run dry at some point.
Old 08-29-2015 | 12:46 PM
Aftyer looking at a actual image of the parts kit the ring appears to be some form of plastic or other synthetic material.
After tear down I'm replacing everthing but the shaft. All the seals, the ring, bearings etc. The actual shaft is OK.
