What ADD-ON hydraulic Steering is best to buy?? >
Old 09-01-2015 | 02:02 PM
Originally Posted by Brembofreak
Hello
Thanks to all for your meanings! And i happy to get more infos about best setup for my boat,as i try to hold it for next years!
I made engine (new 8.2 with CMI and Whiplle PCM) and all technic new last 2 years! So also transom and complet steering from rear to front is new.thats why i like to have only an Add-On steering. the mayfair has option to make later second cylinder at other side and i like design from the mount on the Drive,as it fit on my swept back upper without any mods.
Of cours it is a matter of price,why i like to take first only one cylinder,but maybe later i add second.
The Price for add-on with only one is much lower and i like also to buy long trim tabs next time ,as no one on my boat.
When i buy steering with 2 cylinders,i think no money for Tab this winter!!
So what you mean is bets to do first??
anyone drive the Mayfair stuff?
And i understand not rela the problem with one ram and gimble trouble and not balanced!!??
Thanks for help!
Fact is that a dealer here in germany has an mayfair for sale with single cylinder but new and all complet! that makes it more easy to take this .all other i must import from usa!
Michael
I have an imco single full hydraulic system and it corrected the chime walk. My boat does 80mph and it rides great. I would also recommend the imco system. Tell the people what you have and they will recommend the right set up for you. Great people to work with at the company.
conneroutlaw is offline
Old 09-02-2015 | 07:53 AM
cig28's Avatar
I use Imco dual ram on my boat, Imco's service is second to none. Ron at Imco will walk you thru any problems you have installing your system. If you call and get the answering machine he calls back and for me that speaks volumes.
cig28 is offline
Old 09-02-2015 | 08:11 AM
I shopped all brands and I went with The Mayfair Full Hydraulic Steering System sold by CP Performance and am very happy with it
Originally Posted by ezstriper
C-P performance sell the hardin marine and is a good set-up..but unless you go full Hyd just a bandaid and you are in a very touchy area speed wise..
Jat64 is offline
Old 09-02-2015 | 12:34 PM
CIG3's Avatar
Other than Latham, Mayfair is top of the line stuff. Not to knock IMCO as they are great as well. But if you have Mayfair available local to you I would not hesitate. Brett May the original producer of Mayfair steering is now with Everett Performance (Zeiger). We had the first Mayfair sterring on our old race boat Rascal and it was still in perfect working order when we sold the boat 23 years later.
CIG3 is offline
Old 09-03-2015 | 07:46 AM
Ok,Thanks for this much Infos!
I have herad now from someone with 496 Ho that tell me that his Pump can not work with 2 cylinders! He can only mount one!!
Does anyone with 496 has 2 rams on it?
My new 8.2 has same Pump like 496 and it would be crasy to buy 2 ram and it work not!
michael
Brembofreak is offline
Old 09-03-2015 | 07:55 AM
I don't see why your 496 pump would not work with 2 cylinders. I can turn my boat (full Latham system) without having the engine running pretty easily. Would recommend full system rather than add on night and day difference.
badluck is offline
Old 09-04-2015 | 01:15 AM
Are here some Guys with 496 or newer 8.2 Mag HO that use Dual Ram add-on steering?
The newer engines have other servopumps with seperate oil reservoir.
Not like the older pumps that was complet.
Real like to know if this new pumps work with 2 rams as someone here in Germany say it did only work with one ram!
They have test at one engine.But maybe this pump was not ok ??
Hope some guys can tell me it will work with 2 cylinders.
Michael
Old 09-12-2015 | 12:45 PM
After think about it,i buy now 2 new imco cylinders with mounting bracket!
then i have send 2 emails to Rick from imco,as i like to buy the rest there!
means Hoses,adapter for merc brzil steering cylinder an top end plated for bravo to take the 2 cylinders!
but i get no feedback or any answer from imco!
what to do now?
Can i mount the Mayfair topend Cap on my bravo?(i like this easy srew on desig much) did the imco cylinder will fit there?
Maybe anyone has cap for dual cylinders for bravo sweptback version used??
hope someone can help.
thanks. michael
Old 12-16-2015 | 01:30 PM
The deal with Imco cylinders did not work! When i get,i see that they send 2 diffrent.So i send back the parts!
Now is clear that i buy an Mayfair Addon steering Dualram for single Bravo!I love design of their Wingplate most and it only must srew on Upper!
Only thing tha not clear for me is what version i need,means what version is better for me!
They have 2 Version with diffrent mounting size from middle of the drive!
The version with longer cylinders and mounting location more outside is 160 dollar lower from price!
And i real dont know what works better?why are 2 versions???
Can anyone answer this question? Thanks for your help!
Best regards
michael
(Ram Mounting Location is 17-3/4" from the side of the Gimbal Housing)
(Ram Mounting Location is 9" from the side of the Gimbal Housing)
Old 12-24-2015 | 02:27 AM
No one can help or know?
what is better to buy? mounting near or far from transom??
I like to order now a new steering and need this info!
Boat is an 232 with 500 HP!
Best regards!
Michael
