where to install WP relief valve >
Old 09-07-2015 | 08:07 PM
Default where to install WP relief valve
I have a 98 312 fastech w/ stock 502 mpi's, At wot one engine is running at 30-33lbs of water pressure and the other is 28-30. I think I need to install relief valves but do not know where to plumb them in.
thanks
cjohns05 is offline
Old 09-07-2015 | 08:12 PM
Thats what my 454 runs. All stock cooling system.
79formula is offline
Old 09-07-2015 | 08:14 PM
everyone Ive ever talked says it needs to be down around 15-20.
cjohns05 is offline
Old 09-08-2015 | 01:37 AM
That would be ideal, but my 2000 502mpi's also run into 30-35psi range. They had 250hrs when I bought the boat and now have close to 600hrs on them.
I thought about adding relief valves, but figured its been fine for a lot of hours the way it is.
Griff is offline
Old 09-08-2015 | 01:47 PM
Don't think it makes any difference as long as you have some pressure.....10-40 PSI all work.
BenPerfected is offline
Old 09-08-2015 | 01:53 PM
up to 35 is not too much of a concern, however if the boat were any faster it might be... rather than a pressure relief valve my suggestion would be to trim your water pickups a hair... start with about .030 off the deepest part of the tip... I'm sure this will help reduce your pressure to an acceptable PSI
adk61 is offline
Old 09-08-2015 | 02:00 PM
1 MAIDEN AMERICA's Avatar
Pull the exhaust risers and hoses, T-stat hoses, and descale the rust. Let it flow.
1 MAIDEN AMERICA is offline
