Question for Mr. Moore-502 EFI >
Old 09-16-2002 | 11:44 AM
Default Question for Mr. Moore-502 EFI
Dennis,
Regarding the 502 cam thread, I am using the Crane H-278 in a 95 502 EFI with the stock ECU and GIL manifolds. Would increasing the fuel rail pressure provide any benefit with this setup?
Thanks for any advice and it certainly is a plus having someone of your stature contributing to the forum.
Warren
wwbobb is offline
Old 09-16-2002 | 01:50 PM
Dennis Moore
Default Adjustable Fuel Pressure Regulator
Buy a EFI fuel pressure tester at a local auto parts store and check your fuel pressure. Increasing fuel rail pressure works well on a marine engine (not on an automotive engine) but remember it is only a cheap fix. The only thing you can do is test and readjust and test and readjust. It is much cheaper than sending in the ECM to have it reprogramed several times until you/they get it right (but not as good).
Sincerely
Dennis Moore
FAMILY AND PERFORMANCE BOATING MAGAZINE
Old 09-16-2002 | 08:01 PM
Dennis,
Thank you for the reply. I will try as you suggested.
Warren
wwbobb is offline
Old 09-17-2002 | 09:26 AM
Dave1972's Avatar
Dennis,
So you are saying that by increasing the fuel pressure to the injectors, that we can see a performance gain? I am running 35psi on the injector rail....what would you recommend? I also have a freshly rebuilt 502MPI with a custom cam and new forged pistons, mild head work, and roller valve train.
Dave1972 is offline
GSS0816
5
07-25-2007 02:11 PM
GSS0816
10
07-04-2007 02:11 PM
thedonz
2
06-18-2004 01:19 PM
mrp
11
09-19-2003 08:05 PM
BryanTuvell
4
02-26-2003 02:17 PM
