500hp carbed thermostats >
Old 09-13-2015 | 02:10 PM
Default 500hp carbed thermostats
I bought this boat used 3 years ago from an estate where the owner died so I have no references.
I went to change my thermostats and was surprised at what I saw on the previous ones. When I popped the top cover the thermostats were sitting right there on top of the sleeve. I checked the parts diagrams for the 500 and it showed what I was used to seeing in my previous engines- thermostat goes down in the housing, then gasket, then sleeve and then top cover.
Can someone with experience enlighten me as to the proper install?
WHIPLASH is offline
Old 09-13-2015 | 02:43 PM
BUP
OEM stock HP 500 the stainless steel T stat is recommended not the brass one
from the bottom up the engine block, t stat housing, t stat, O ring, spacer, gasket and then t stat cover, lifting ring and lastly 2 bolts
current t stat for this app should be 140 degrees. .
BUP is offline
Old 09-14-2015 | 10:21 AM
Thanks! That is what I thought. I have the proper thermostat, o ring, brass sleeves and gaskets but wanted to make sure before installing.
WHIPLASH is offline
