What happened
#31
In the boat with my headers and my ignition box was the only differences my fuel pump also. 6.5 to 7 psi on the fuel pressure
#34
What carb do you have on it? I think the only way the A/F would go lean is if somebody played with the emulsion or the air bleeds. That controls the start of the boosters. Have you checked your fuel line from the tank to the pump?
#36
Well finally went to check on my engine. Lifter stuck on the intake valve and the rest you can see. Checking their build sheets it appears the lifter bores were tight. So the human factor strikes again. The bores were measured and recorded and some how missed getting fixed.
The builder is stand up man and is taking care of it.
We had a good discussion about oil. No more off the shelf street oil for me. It was a brand name synthetic.
#38
#39
#40
Yes both valves were broke. I did not take it apart. I borrowed a bore camera from work and checked it out before I took it to them. He told me the intake lifter stuck and started the carnage. They had to use a slide hammer to remove it.
