Broken output shaft & coupler >
Old 09-24-2015 | 04:06 PM
articfriends's Avatar
I would be surprised to hear a drive input shaft sheared off, it sees much less torque than the vert or prop shaft and has sorta a torsional action to it because of length, how much hp /tq do you have, what props?
articfriends is offline
Old 09-24-2015 | 04:09 PM
I see you have 1000 hp, my 272 Baja had over 1000 hp and ft lbs of tq, one drive had stock std input shaft and ujoints, my other drive had xr input shaft and u joints, sheared plenty of vert shafts and prop shafts but input shafts still looked like new, I guess it could happen but again, I would be surprised, wondering if your running tall 5 blades that really stress it or something? Smitty
Old 09-24-2015 | 05:01 PM
Am I correct to assume that this is the forward engine in a staggered application ?
JaayTeee is offline
Old 09-24-2015 | 05:11 PM
Triple boat ? If so , same pitch on all props or higher on center eng ?
PARASAIL941 is offline
Old 09-24-2015 | 05:34 PM
Yes you are correct.
jdflchr is offline
Old 09-24-2015 | 05:40 PM
1,000hp per motor, props are labed Herings 17/38. It's not the drive input shaft that I'm having a problem with my SCX drives are fine. It's staggered engine boat and it's the forward engine and it has a output shaft that goes in the coupler to a drive shaft then back to the input shaft from the drive ( SCX 4's )
jdflchr is offline
Old 09-24-2015 | 05:41 PM
Not a triple boat.
jdflchr is offline
Old 09-24-2015 | 05:44 PM
Props are 17/38 5 blade Herings that have been labed. I know I'm putting a lot of load on the shaft that's why I'm looking for a stranger one.
jdflchr is offline
Old 09-24-2015 | 06:06 PM
Sonic30ss's Avatar
Try Denny's Drivshaft in Buffalo NY
He should be able to eliminate the weak link and help you find the next one 😉
Sonic30ss is offline
Old 09-24-2015 | 06:13 PM
He should be able to eliminate the weak link and help you find the next one 
Thank you I will look them up. I'm afraid of what the next weak link may be.
jdflchr is offline
