Broken output shaft & coupler >
Old 09-26-2015 | 05:06 PM
  #41
I have a heavy duty PTO adapter for big block Chevy that bolts to the crankshaft using crank bolts and provides a 4 bolt pattern for u-joint flange. We use them in jet drive applications. I'd ship it to you for $75 bux, it is new, un-used. Give me an email and I'll send you pictures.
No Coast is offline
Old 09-26-2015 | 05:51 PM
  #42
mrv8outboard's Avatar
coolrunning racing
Well that explains a plausible cause. It is able to flex and move around with out the pilot bushing to keep it aligned from the bearing through the coupler to the crank.
mrv8outboard is offline
Old 09-26-2015 | 06:50 PM
  #43
I would like to see it. I'm not sure it's going to work for me. I would have to take out the coupler and make a longer drive shaft. All stuff I can do but not sure how I feel about running the boat without a coupler. Email is [email protected] I'll take a look and see of it will work.
jdflchr is offline
Old 09-26-2015 | 06:55 PM
  #44
I'm not convinced that's the whole problem but I'm sure it didn't help. I ordered a bushing today so it will be one in when it goes back together. I have a few leads on a custom built shaft that will be stronger so between those two things I hope I will not have this problem anymore. Next problem will be blowing out couplers all the time. Thanks for your help!
jdflchr is offline
Old 09-27-2015 | 12:55 PM
  #45
Running without a coupler shouldn't be a problem. That is the standard way with Stelling ext boxes.
I have Stelling boxes and my engines are also moved forward about 16" and I run drive shafts.
I don't have nearly your HP though, but the boat originally had 750's with this set up.
Griff is offline
Old 09-27-2015 | 10:47 PM
  #46
Check with Bam also. I know they make Flanges for the trannies. So he might have some leads or suggestions. He's on the board here also.
cheech is offline
Old 09-28-2015 | 08:56 AM
  #47
I called Bam when I broke the first one. They didn't have anything at that time. Maybe I'll check with them again. Thanks
jdflchr is offline
Old 09-29-2015 | 10:09 PM
  #48
DriveGuardian would definitely eliminate your coupler issues and can easily handle your HP levels. MDC can also build a custom input shaft for you that can handle 1,000+HP without breaking.
GF?
I didn't even know what a Drive Guardian was, I had to look it up. That's a great idea. I just bought a new coupler and bearing today if I can't find a better shaft soon I'll get one more stock one just because I'm going to Key West poker run with this boat and I'm running out of time. I'll be looking into a drive guardian for next years boating season. Thanks for the idea.
Got Freedom? is offline
Old 09-30-2015 | 11:05 AM
  #49
Maybe this would help? Drive plate damper.
http://www.***************.com/hardi...rough-1800-hp/
Baja Rooster is offline
Old 10-03-2015 | 06:38 AM
  #50
GF?
Who is MDC? It's not my drive input shaft that I'm breaking but if they make custom shafts I would like to talk to them.
jdflchr is offline
