mechanical fuel pump
Will changing the pump assembly on a mechanical 110 GPH fuel pump increase the GPH on a stock marine 330 HP fuel pump? Cant find a marine 110 GPH pump that will bolt to the sea pump.
Yes. It's a common mod to do. The bad news is 110 is inadequate for that kind of power. On paper it may spec out, but not really in practical application. I'd use the 130gph Holley pump with a bypass regulator set up. Fwiw the 3/8" line from the tank proved anemic for my 500hp.
