Valve spring pressures >
Old 09-28-2015 | 12:26 PM
Originally Posted by Bawana
Great find.... Exactly as I said too much spring robs power. Mild when do you have time to work? you seem to spend a ton of time doing research, which is great for everyone on OSO but your wife must never get any time to .. well you know.... LOL
it doesnt take me long to get things done
MILD THUNDER is offline
Old 09-28-2015 | 12:38 PM
We'll just leave that one be!!
abones is offline
Old 09-28-2015 | 12:51 PM
I run a moderate lift/ duration hyd. roller with 175-442 springs all i need to keep the valvetrain intact.we run for extended periods at 6k and above. My belief is that you must be able to close the valve gently enough not to damage it but with enough authority to keep in on the seat at higher RPMs I also believe that the closing pressure is engine specific to what you are trying to accomplish. I>E> n/a, turboed, Supered, NOS, etc. (as Mark expliained in his post)
abones is offline
Old 09-28-2015 | 12:56 PM
articfriends's Avatar
I run 190 seat/490 open but at 14 psi of boostwe are adding extra to acct for area of valve x boost trying to force intake open
articfriends is offline
Old 09-28-2015 | 01:03 PM
Originally Posted by 10x
Yeah... That's what they all say, but only to extend the life of the lifter.
I tried 140# on the seat and about 385# at 600 lift, and with a mild (230-235) duration cam everything was fine till 5600 rpm. No matter what I did, the engines fell flat at 5800. End of the season I pulled the engines to make a few changes.When I lifted the heads to check the valve springs, cause I found signs of valve float, I found almost half of my valves were being pushed through the retainers. Some stems were flush with the locks. Bottoms of some of the roller rockers were hitting the retainers.
What a F'n mess. Bottom line here is no one expects you to run more than 5450 rpm. I think that's what the mercruiser rev limiters are set for at the factory. When you start going over those rpm's, those light v/s combinations can't handle it.
I had valve float so bad, it's a miracle i did'nt lose a valve.
After many lenghty conversations with a marine (offshore) technication at Crane, he finally gave up the truth on spring pressures, rpm's and longivity of hyd. roller lifters. And if you want to turn 6000+ rpm's and make the bigger hp, you CAN'T expect your valve train and especially hyd rollers to last. It cuts their life in half, at the best.
Now we run 175# on the seat, and 490# at 650 lift, and hav'nt had any valve train issue in 2 seasons.
Originally Posted by Reed Jensen
There is a common misconception that the energy to compress the springs is lost.. not so.. the majority of it is returned on the back side of the camshaft. The energy that is lost is called hysterisis, which is internal friction in the spring itself. This is what causes the spring to heat up. If you were to graph the opening and closing rates on a linear graph.. then it becomes obvious that the valve is lifted off the seat, accelerated to full opening.. and then decelerated and slowly lowered onto the seat... The spring pressure isn't as big a factor on wear as you would think. But.. having the valve not follow the cam,,, the valve then "crashes" onto the seat.. This is much more damaging. Also it tends to hammer the keeper into the valve spring retainer. If you are using light weight retainers, they will begin to expand in the area of the keepers and quickly fail. Sometimes they will fail when not even running the engine hard. They have just give up and let the valve keepers slide through.
Mikes @ High Flow likes higher spring pressures, I forget his explanation but I trust his expertise. Your valves and seats are probably TIRED from all that bouncing around with that low seat pressure.
ICDEDPPL is offline
Old 09-28-2015 | 01:16 PM
You are ALWAYS better off with to much than not enough.
Black Baja is offline
Old 09-28-2015 | 01:18 PM
Considering these cams and spring combo been in the engines since 2005, and lobes still look good, never broke a lifter, tuliped or damaged a valve, id say its doing ok.
However, my cams are not overly aggressive lobes. I wouldnt try running .400+ lobes, 240* duration, and with light springs.
Merc 525s have similar cams as me, and run less than 120lbs on the seat, and less than 400lbs open if i recall. My springs, a certainly not "light " in comparison to the majority of hyd roller springs out in the field that running successfully.
While 6000 rpm is alot, its still a long way from 7500-8500rpm bbc stuff that gets built daily. When a cam has a big lobe, and short duration, the lifter wants to ski jump off the nose of the lobe much easier, so it needs lots of spring.
These are things that separate a drag race camshaft profile, from an endurance engine camshaft. If it didnt matter, we would all be running .750 lift with little 240* duration cams.
Old 09-28-2015 | 01:24 PM
I can atttest to your boat being bad azz and runs !!!
Old 09-28-2015 | 01:32 PM
Fyi, im not suggesting what i think is right or wrong. I can only attest to whats worked for me, and trying to see what has actually worked for others in the field, long term wise.
Old 09-28-2015 | 01:36 PM
This is what i'm refering to if you take away the 14# boost pressures would be 176/476, so we can't say what the perfect presure is for a hyd roller. it should be engine specific.
abones is offline
