Valve spring pressures >
Old 09-29-2015 | 06:13 AM
  #41
Originally Posted by MILD THUNDER
Great info from all parties here. If nothing else, great tech conversation
I don't know why I havent put spring oilers on yet, looks like another add on this winter coming
Spring oilers definitely help cool the springs. I run T&D shaft rockers on my street car. They have an option that have a small hole drilled in each rocker that sprays oil on the springs. Great option to get. I think it was only a $1-2 a rocker option.
underpsi68 is offline
Old 09-29-2015 | 08:27 AM
  #42
Originally Posted by articfriends
Abones, theres a little more to it than that though, 2.300 intake, minus .343 for dia of stem lets say 2.0 " for discussion , 2x 3.14 =6.25" area x 14 psi boost = 85 roughly, so to help control intake valve under boost it would take a extra 85 lbs give or take so really my 490 is more like 405 on intake, take away 5% for springs going away before rebuild interval and even though 490 sounds sorta big it gets small quick, in my opinion. Does a NA motor need 490, no but it better have at least 400 to turn 6k+, Smitty
Yes very good info, which brings up another thought for you guys running power adders and increasing cyl pressures. Think about the added stress put on the exhaust rocker, stud, push rod and lifter to open the exaust valve after boosting and blowing an NOS shot! along with an overly high tension spring,, any thoughts guys??
abones is offline
Old 09-29-2015 | 08:34 AM
  #43
SB
Originally Posted by abones
Think about the added stress put on the exhaust rocker, stud, push rod and lifter to open the exaust valve after boosting and blowing an NOS shot! ...... any thoughts guys??
In your order....
TD
Manton
Jesel
It's all just $$$$$. LOL.
SB is offline
Old 09-29-2015 | 09:11 AM
  #44
$$$$$ and lots of them, is what I personally don't have, so that is why I try to get a decent power level that will last for a long time and then learn to be happy with it on a low budget engine build, and I think I'm there now.
Thanks to all for the good info,
abones is offline
Old 09-30-2015 | 06:41 AM
  #45
MER Performance's Avatar
Originally Posted by HyFive578
Can I ask why you chose the 8205+ springs? versus a 8005A or 8005+ for instance?
Tool Room Spring, also the difference in installed height forces as the spring is compressed. Rate is the same, but forces are not...
MER Performance is offline
Old 09-30-2015 | 02:09 PM
  #46
Just curious, what's your installed height? Is this a stock 525 build?
HyFive578 is offline
Old 03-19-2026 | 04:06 AM
  #47
Originally Posted by SB
Ice - in fact, some manufacturers are starting to use deeper spring pockets and/or 'cages' (my term) for the lower prt of the springs to hold oil. Helps keep temps down and controls harmonics a little better. As most know now, Cup and some other forms of endurance racing go one step much further, and that is to 'flood' the valve covers with oil.
Your choice of having spring oilers can only help...that's for sure.
GM was doing similar things with the truck Peanut Port heads in the '80s.
Sometimes tech goes full circle.
Tartilla is offline
Old 03-19-2026 | 04:20 AM
  #48
Legitimate question, I am curious to what guys are running for spring pressures, on their big block marine hydraulic roller engines, and how many rpm you turn?
I have catalogs from crane, comp, lunati, crower, isky, elgin, howards, etc. When looking thru their books, most give a spring part number, to go with the cam. Across the board, it seems pretty common, to see a spring setup that comes in around 150ish closed, and 400-450 open pressure for a bbc hyd roller.
For example, the every so popular crane "741" and "651" cams, are spec'd with a crane 99896 spring.
Mine are setup at 165/450ish, pretty consistantly run 5500-5700 wide open, and turned to 6200 on the dyno with no signs of valve float.
Icdedppl is running 225/575 on his crane 651 cams. I know the morel hi rev lifters call for that spring pressure, but , they also are supposed to support 7,000+ RPM, which he will never ever see.
Besides avoiding loss of control, what is the purpose of running high spring pressures? And what are the negatives of too much pressure? Lets just say theoretically, a 160/460 would keep his valvetrain under control at 6000RPM, what benefit is there to having an extra 100psi of force over the nose, if it isnt needed?
What's everyone running for springs?
I was just going through the Crane catalog, looking for the springs they spec'd for the 731 cam.
Oddly, Crane specs the same 99896 Spring for every cam from the 204deg @0.050" 0.486" lift...to the 262deg @0.050" 0.680" lift Hyd Roller cams.
Seems a bit excessive for the lower lift and shorter duration cams, considering these are milder lobe designs.
Once you see what the valves and springs do at high rpm with high frame rate cameras, you wonder how the valve stems and springs even survive at all. The spring twists when the valve is closed and on the seat...and the stem sways around! This is at 8500rpm, and there's more going on than what we deal with, but the principles are the same.
Seat bounce and issues are also affected by seat materials. Harder seats and narrow seat widths will cause more issues. Valves shed 75% of their heat through the seat contact, and 25% through the step.
Tartilla is offline
