502 compression specs >
Old 09-28-2015 | 02:48 AM
Originally Posted by Baja170
Most of the guys I talk to say leakdown is just as important as compression and when they did your compression check did they oil anything or go back with compressed air to see where the leak was? Just curious, I am no expert but I have a lot of toys I have been dealing with for years.
i have seen similar numbers on every 502 i work on..they need to get hot to get good numbers and the butterfly wide open..
FIXX is offline
Old 09-28-2015 | 06:10 AM
Livorsi also had a kit that they used a Procharger. This was back b4 Procharger ever had a marine side.
Black Baja is offline
Old 09-28-2015 | 07:26 AM
onesickpantera's Avatar
Originally Posted by dp9650
I have photos, I wish I could figure out how to post them. It is a twin setup, two air pipes, one from each blower. Absolutely positive. I have never seen anything like it.
Interesting. You can post the pics on photobucket and link them here.
onesickpantera is offline
X2...especially if the boat has been sitting.
Old 09-28-2015 | 07:51 AM
Thank you for the responses, gives me a little more to go on.
dp9650 is offline
