Bravo 3 clunks when engaging in gear >
Old 09-27-2015 | 12:02 PM
Default Bravo 3 clunks when engaging in gear
My 2003 SeaRay 340DA has twin 8.1s with Bravo 3s. When I engage the starboard side, it is silent and smooth. When I engage the port, there is a small "clunk" similar to an older alpha drive sounding when it engages. The noise is not loud, and there is no vibration. The RPMs are identical. Any suggestions on what I can look at before I remove the drive ?
kenkscarab is offline
Old 09-27-2015 | 05:07 PM
Check the props and make sure they are both tight. The front one needs a big special wrench, the rear is 36 mm socket. They clunk when loose.
No Coast is offline
Old 09-27-2015 | 08:07 PM
From: East Texas Waterfront- running errands if anyone asks
Gimble bearing.
Flightplan is offline
Old 09-27-2015 | 11:44 PM
Thanks, that will be the first issue I look at.
Old 09-27-2015 | 11:48 PM
Thanks for your reply.
