454 Flywheel >
454 Flywheel
454 Flywheel
Old 09-27-2015 | 02:01 PM
Default 454 Flywheel
I am building a 454 for my boat, the original engine is 1989 454 with a Bravo 1 and is still in the boat running fine,. The engine I am putting together I want balance the rotating assembly, so I need a flywheel or take my current engine out which I don't want to do until the new engine is ready I have purchased a new HD drive coupler # 861523A11 My question is, the mercruiser flywheel is $400+ and a SFI rated Hays flywheel is something like $288 does anyone know if this coupler will bolt up to the Hays flywheel and what the difference's are if any?
Thx
skier207 is offline
Old 09-27-2015 | 04:39 PM
GPM
The coupler will bolt right up the the Hays flywheel, the only difference is the Hays is a lot stronger. You can choose internal or external balance depending how you build your motor.
GPM is online now
Old 09-27-2015 | 06:00 PM
Thanks, I looked all over the internet (well almost) couldn't find that info anywhere.
Kevin
skier207 is offline
Old 09-28-2015 | 06:17 AM
can run a std GM manual trans flywheel for a 454
ezstriper is offline
Old 09-28-2015 | 09:33 AM
I'm running a hayes that was on the boat when I got it. Machine shop rebalanced it since I went to internal balance.
apollard is offline
