Back yard engine builders. >
Old 09-29-2015 | 10:14 PM
Tinkerer's Avatar
Apollard - The bolts on my pump weren't tight at all. I took it apart and cleaned and checked everything, Then I used green lock tight when I put the bolts back on. The bolts won't come back out but IF the engine comes back apart a complete new pump will go back in.
Tinkerer is offline
Old 09-30-2015 | 07:11 AM
Yep, I do that now. So much for buying tried and true American parts. Now you have to check them also.
apollard is offline
Old 09-30-2015 | 09:20 AM
Originally Posted by Baja Rooster
Sometimes you buy all the right parts, tighten every nut to perfection, and even check the lifter bore clearances, but...
Dang. All we sucked in was this dowel...
Solar Centaur , IIRC
Cole2534 is offline
Old 10-03-2015 | 12:20 PM
another fun way to kill a turbo, forget to hook up waste gate.
dereknkathy is offline
