Transmission tube >
Transmission tube
Transmission tube
Old 10-01-2015 | 11:12 AM
Default Transmission tube
I'm looking for one of these the other trans is a bam 900 and it has a short stick on it no tube. seeing if Bam can help me out with what I have
dennis r is offline
Old 10-01-2015 | 11:41 AM
Its a dipstick from a trs setup. Part #48464 no longer avail from merc. I would try ebay
MILD THUNDER is offline
Old 10-01-2015 | 03:14 PM
Question
Hey Joe would he be able to put a little bead of weld on it ? It`s what I`d do but just wanted to check with you first.
ICDEDPPL is offline
Old 10-01-2015 | 05:13 PM
Looks like a dipstick from a MercTrans II OR a TRS reservoir. For the most part the same except the trans one is longer. You can get one from this guy http://www.kcmarinetr.com/MercTrans-TRTRS.aspx. If it's for the reservoir you can cut it down. Is this for the trans your asking about in your other post?
picklenjim is offline
Old 10-02-2015 | 07:55 AM
looks like the same one from my BW velvet drive
ezstriper is offline
Old 10-02-2015 | 04:38 PM
Yes it is from the trans in my other post
dennis r is offline
