AFR 265 Heads any thoughts/experiences >
Old 10-03-2015 | 02:38 PM
Default AFR 265 Heads any thoughts/experiences
Debating between having my 781's completely reworked (2.17/1.88 port/blend/bowl work) or just buying a set of the AFR 265 "as cast" setup.
Anybody running the AFR? I would be interested in how they worked for you.
At only $600 difference after I sell the 781s that should be only $200-300 total dif. Don't want to waste money but don't want to leave inexpensive power ignored.
Looking forward to hear any thoughts. Thank you.
GLENAMY 242SS is offline
Old 10-04-2015 | 07:45 AM
Here's some things I've found....
http://www.offshoreonly.com/forums/g...-265-oval.html
http://www.offshoreonly.com/forums/g...omparison.html
http://www.hotrod.com/how-to/engine/...ig-block-test/
Jonesyfxr is offline
Old 10-04-2015 | 07:58 AM
I would go with the aftermarket heads. Comparable heads, that will perform similar to the 265 AFR, if you are looking for a smaller oval port smaller chamber cc head.
Trick Flow 280 has 113cc chamber
Dart 275 has 110cc chamber
Brodix 270 110cc chamber
MILD THUNDER is offline
Old 10-04-2015 | 10:04 AM
John, good reads, thanks.
Old 10-04-2015 | 04:48 PM
Any time buddy!!
Old 10-04-2015 | 07:48 PM
Rookie's Avatar
What is you base engine build? Is this the last engine you plan on building? If these are for a 454 cool, but what if you eventually want to build a 502/540/557 or 565? You then need to step up to another head. Why not buy an AFR 305/315 or 325 now and leave room for future builds. I could be way off base, just my thoughts.
Rookie is offline
Old 10-04-2015 | 08:13 PM
Full Force's Avatar
NO MATTER WHAT, you buy bare and have assembled.... then you know exactly what you have, I am happy with my AFR, but should have had them built...
Full Force is offline
Old 10-04-2015 | 08:27 PM
This should be it for the foreseeable future.
Old 10-04-2015 | 11:29 PM
I put a set of them on my 525sc upgrade, did a cam, and head combo through Bob, and made 689.4hp and 675ft lbs of tq with a set of partially cnc'd 265 AFR's. No complaints here so far after 1 season on them.
ealesh33 is offline
