What does this flush out? >
Old 10-06-2015 | 08:31 AM
Thanks Brian,
stimleck is offline
Old 10-06-2015 | 09:19 AM
rak rua's Avatar
99% sure the guys above are correct but I have the same fitting on my Fountain. On my boat it is the filler for the fresh water tank! I know you've got a 496 vs my outboards but double check where the hose on the back goes to.
RR
rak rua is offline
Old 10-07-2015 | 09:34 AM
My velocity has the same setup. It's a good idea when running the engine through the fresh water flush to block off the low water pickups in the outdrive. Mine has a dual pick up and I tape both shut up before starting the engine. The sea water pump primes much quicker with the lower taped off.
Ryan00TJ is offline
