Upper swivel shaft nut wrench size.
On a Bravo drive, what size is the nut size on the upper swivel shaft that holds the steering lever on ? My wrenches go up to 1 inch, and my guess is either 1 1/16 or 1 1/8. Don't feel like buying a wrench on a guess.
Thx
Smitty
Thx
Smitty
Thanks Bup. I figured that's what it might be. Stupid size if you ask me.
Your welcome anytime.
Depending on access to the nut whether JR Marine method or Merc access hole plug kit, I have some special wrenches for this but they are not cheap want to say 65 to 75 bucks per one. I will have to double check. I need to get them out of storage. They worked really for that.
Don't forget when you reinstall the nut you have to tighten to a spec clearance what Merc calls for. IMO really a poor design Merc transom assemblies and shift cable.
Bup
I have my motor out so I am working from inside. Now that I know what wrench I need, I need to find a thin one or get a cheap one and grind it down. Any suggestions for that ? And how does the lower swivel come out ? My guess is get the lower one out and slide the upper one down. Also the side bolts look like a special tool is needed ? Looks like a big Torx bit ?
Thx.
Thx.
Bup
Thx.
Thx.
this is JRs kit you can buy, but I grinded them myself. Had measurements somewhere on where to grind.
[ATTACH=CONFIG]546145[/ATTACH]
Bup
Thx.
Thx.
There is a hinge pin socket that Merc sells.....I just made one using a 12 point bolt of the same size of the hinge pin and welded a nut to it.
I have a special wrench that is custom made for the nut on the swivel shaft. It might be best to just pull off the whole transom assembly and work on it that way. Not hard to do at all and so much easier to work on that side of the transom assembly especially the nut for the swivel shaft.
Just make sure you install a new transom seal when reinstall the transom assembly. Plus do not forget to clean the transom exterior very well before the reinstall as well.
the hinge pins on the side of the gimbal ring might be locktited so heat them with a heat lamp or a heat gun before taking out with the hinge pin tool and proper socket for the tool..
No offense it might be best to buy Mercruiser OEM - BRAVO service manual per you year / serial number run. Best money you can ever spend and I have them used for sale. New the cost is around 99 bucks depending on which Bravo manual needed. I sell them for around 60 bucks shipped to your door.
I Would need your outdrive serial number and year model to get the proper OEM manual.
