Cam Suggestions for a 540 >
Old 10-09-2015 | 11:23 AM
  #61
Call Bob @ Cam Motion, Baton Rouge, LA and/or Bob M. @ Kenetics. They will go discuss your boat your build and your expectations and grind a cam for your needs.
GLENAMY 242SS is offline
Old 10-09-2015 | 11:46 AM
  #62
Full Force's Avatar
My old engines 565 CI with 236/[email protected] lift on a 114, 598hp@5200 and 661tq@4400, those engines would still be going strong if it did not spit a rod They peaked out at 5200 they went 5500 in my boat and ran really good and reliable until it's been a rotten I did not build them they had a lot of junk parts in them but they made good power and excellent torque
Full Force is offline
Old 10-09-2015 | 12:09 PM
  #63
What heads were you running on it ??
22MTR is offline
Old 10-09-2015 | 12:30 PM
  #64
Full Force's Avatar
Pro comp, I bought those engines done out of a different boat and had to do lots to make them live 2 seasons (low oil pressures, rework heads with inconel) things like that but they pushed my heavy mistress very easy
Had all Chinese parts and stayed together valvetrain wise for 2 seasons I had them and I abuse things very hard.
Old 10-09-2015 | 12:33 PM
  #65
F-2 Speedy's Avatar
I have custom grind in my 540's, if I can find the cam card I'll post the specs
F-2 Speedy is offline
Old 10-09-2015 | 03:57 PM
  #66
I am looking forward to seeing them.
22MTR is offline
Old 10-11-2015 | 11:46 AM
  #67
Originally Posted by MILD THUNDER
I did.
"The low lift profiles were designed for street and marine use. The low lift adds dependability and reliability for extend-
ed use applications. The high lift versions of the hydraulic rollers are designed for all out applications where high lift
is desired because of cylinder head or engine modifications. They function well for street and strip. These lobes run
well in big cubic inch marine engines."
Crane also has a 680 lift 244 grind they say is ok for a marine application.
Anyone running 680, 700 lift hyd cams going 300 hours on their valvetrains? I know its done everyday with .360 lobes. Anyone doing it with .400+ lobes ?
theres a reason a stock GM roller big block with a whopping .483 lift, can go 1500 hours, and a .612-.630 merc only goes 300 hours or so? Safe to assume increasing lift adds power, while reducing valvetrain life generally?
How much power is gained even with 335 afrs, by going from a .370 lobe to a .400 lobe? How much of a reduction in valvetrain life ? How much faster will the boat go?
MT thank you for the link.
After reading and digesting the info in the comp cams custom grind catalogue and plugging some numbers into dynosim the crane 741 gets me where very close to where I want to be . Just wondering if I play with more duration and less lift if I can get the same power and be easier on the valve train.
22MTR is offline
Old 10-11-2015 | 02:02 PM
  #68
Crane 741 is a great choice, easy on the valve train, nice around the dock and good upper midrange torque.
You could also call Bullet Cams, they are pretty sharp too.
kvogt is offline
Old 10-11-2015 | 04:43 PM
  #69
There is one guy at Bullet that it sharp. The rest of them are dumb as a box of rocks.
Black Baja is offline
Old 10-12-2015 | 09:00 AM
  #70
ICDEDPPL is offline
