What do these bearings tell you? >
Old 10-12-2015, 08:41 PM
  #111
bck
Charter Member#568
bck's Avatar
Yes. You're the one who clued me in about them. I made arrangements with him so I could buy/test with them just before the engine problems. The props that I was running were loaners and not for sale. I've got to see where I'm at with the new engines now prop wise
Straight bottoms and flat decks
bck is offline
Old 10-12-2015, 08:45 PM
  #112
bck
Charter Member#568
bck's Avatar
I can't afford to replace parts that aren't broken so I'm going to reuse the 305 heads and current intake. We're going to bump the comp about .5, run a few hundred rpm higher and go more aggressive with the cam to take advantage of the exhaust I have now. I'll try some 4500s with an adapter to my intake also
bck is offline
Old 10-13-2015, 08:44 AM
  #113
Originally Posted by bck
It has t stats. Water temp never budges off 140-150
did you ever mention how much water pressure you have?
sutphen 30 is offline
Old 10-13-2015, 09:59 AM
  #114
bck
Charter Member#568
bck's Avatar
Water press is generally never below 20 when on plane. Measurement taken from intake below t stat housing
bck is offline
Old 10-13-2015, 01:10 PM
  #115
Received 1,834 Likes on 917 Posts
Water temp never moved. Oil temp on only one engine went up to about 240. Maybe a minute or so at that temp
I feel that the bores being both out of round and tapered started taking the pistons out from day one. I believe me getting them hot (240° in just 1 engine) accelerated the process, but the writing was already on the wall for them.
240* oil temp is not too hot and should not be an issue.
Griff is offline
Old 10-13-2015, 01:49 PM
  #116
SORE MEMBER
Wobble's Avatar
Originally Posted by Zone 5
On the remote filter is most likely before the cooler. (The way most stuff is rigged) You can get a bunch of discussions about where and why you should check oil temp before/after cooler. Mine was always before, and ran 230 all day long for 5 years, with no issues.
Really should run the oil filter after the cooler. Coolers often have little beads of solder rolling around in them, next stop is the mains.
If you are talking about where to measure temp then that is another discussion
Wobble is offline
Old 10-13-2015, 04:26 PM
  #117
bck
Charter Member#568
bck's Avatar
I'll verify how the filters are plumbed in relation to the cooler tomorrow. If the temp sender is after the cooler and read 240 how hot would the oil likely have been before the cooler?
bck is offline
Old 10-13-2015, 07:21 PM
  #118
SORE MEMBER
Wobble's Avatar
That depends on the size of the cooler and the water temp, my multipass Teague offshore cooler supposedly can make a 50* drop in temp.
Wobble is offline
Old 10-13-2015, 08:48 PM
  #119
bck
Charter Member#568
bck's Avatar
Oil is cooled through 1 side of a merc bellhousing cooler
bck is offline
Old 10-13-2015, 09:07 PM
  #120
bck
Charter Member#568
bck's Avatar
Found a picture on the phone. Wouldn't you need to know how the fluid flows in side of the filter housing to determine if the sender's are before or after cooling? And how does that flow change as the t-stat opens and closes?
bck is offline
