Out of the box heads? >
Old 10-15-2015 | 05:13 AM
  #61
Originally Posted by MILD THUNDER
Right, so I'm not understanding the "afr valve size" thing?
the bore sizing tool uses the valves that are going to be used as set up.lock the 2 valves into the zeroing block,then take the bore gauge and zero to the size/diameter of the valve.now go measure the clearance.very easy to set up.
sutphen 30 is offline
Old 10-15-2015 | 05:20 AM
  #62
also,the clearance is put into the part,in this case the valve.11/32" intake vale usually measures ~.342" so in a 11/32" guide it would have ~.00175" clearance,same goes for the exhaust vale,they usually measure in at ~.341.so thats why you use the valves in question for checking the guide clearance.
Old 10-15-2015 | 05:25 AM
  #63
What do you generally see out of the AFR heads? When we measured mine @.0018 we thought we would measure a Brodix BB3 to compare. Guide clearance in them was .0013-.0017
Black Baja is offline
Old 10-15-2015 | 06:59 AM
  #64
On the last set of 335's
Intake were.0011-.0014,honed them to.0015 and exhausts were.0014-.0016,opened them up to.0022.motors were 950hp 540's vortex have.
Old 10-15-2015 | 09:55 AM
  #65
What do these videos tell me? that I know Zero and am glad Al K is local lol
stimleck is offline
Old 10-15-2015 | 02:19 PM
  #66
Sutphen, out of curiosity, what is a good exhaust guide clearance on a mild, normally aspirated 600-ish HP engine? Do you need to go quite as large on the clearance? Not talking about extremely cold water temps like Full Force operates in - usually 75* and warmer where I boat.
Budman II is offline
Old 10-15-2015 | 04:02 PM
  #67
MER Performance's Avatar
Originally Posted by Black Baja
With a Sunnen gauge you have to set the tool up with the valves then you can measure the guides.
That's exactly correct !!!!! I have one and also a pointed small bore gauge....
MER Performance is offline
Old 10-15-2015 | 04:27 PM
  #68
Full Force's Avatar
When mine were measured I was informed the sunnen was not good enough or accurate enough, now it's ok to use gimme a fukkin break.....
Full Force is offline
Old 10-15-2015 | 07:51 PM
  #69
.0013-4" on intake and exhaust .0018-9" exhaust,i use good hi temp vitron seals and never see the guides oil the ports.
Old 10-15-2015 | 07:52 PM
  #70
I've been using one forever and a day.
