Electric fuel pump question >
Old 10-11-2015 | 08:29 PM
Default Electric fuel pump question
If my boat does not have a return fuel line can I come out of the fuel regulator return and run back to the fuel water separator which is before the fuel pump.
Warlock98 is offline
Old 10-11-2015 | 09:00 PM
Yes you can. Mercury has done it that way
Bawana is offline
Old 10-11-2015 | 10:35 PM
Merc does it that way, but it can create vapor lock issues.
Griff is offline
Old 10-11-2015 | 10:57 PM
14 apache's Avatar
I think they make a tee that goes in the fuel fill hose. I would set up a return it will have less air bound issues.
14 apache is offline
Old 10-12-2015 | 12:01 AM
They do make a T for that, and it would be a better way to go. But if you can't get to your fuel fill lines, then don't be afraid to go the water sep.
Bawana is offline
Old 10-12-2015 | 04:08 AM
SB
These:
http://www.cpperformance.com/c-500-f...s-returns.aspx
SB is offline
Old 10-12-2015 | 05:53 AM
bandaide...the deal above or a diesel sending unit which has a return line fitting are the best
ezstriper is offline
