How many hours on bigger power stuff? >
Old 11-03-2015 | 08:29 AM
  #81
Panther's Avatar
Frank's Marine Service
Originally Posted by ezstriper
we have been running a drag car turbo LS power 25psi on E85 no intercooler w/meth as well and works great, I tried the same setup on our procharged 509 and even with the smallest jet they said they had slowed the boat down everytime the meth came on...now that was at only 5-6 psi
Similar setup as my buddy but it's a 540, twin turbo @25psi. Somewhere between 1700-2000hp. Car runs 7.70 @185 on the back wheels through the 1/8th. :-0
Panther is offline
Old 11-03-2015 | 08:33 AM
  #82
Panther's Avatar
Originally Posted by Young Performance
That's what scares the hell out of me and has stopped me from using it. It can certainly have it's merits, but there are pitfalls as well.
Mark brought up a great point about AFR's. Straight Methanol has an ideal AFR of something like 7 or 8:1 (I don't know for sure, but I know it's much lower than gas) When you start adding Meth, should the AFR's be brought down. If an engine does it's best at 12.5:1 on straight gas, then what would it be with some Meth mixed in? I guess that would be determined by the amount added, but is it proportional? If you added 10% by volume to the gas, then would the ideal AFR drop by .45 to 12.05:1 (10% the difference between 12.5:1 and 8:1)? I don't know the answer to that. Who does?
Eddie
I'm shooting for 11.5 - 11.8. Currently at 11.2.
Panther is offline
Old 11-03-2015 | 08:42 AM
  #83
Eddie
Stoich for methanol is about 6.5, but this only applies if you're using a methanol afr scale. The O2 sensor reads lambda and then converts it to afr. On the gas scale you'll still want to tune for similar gas afr numbers with the meth, but can usually pick up a bit of power by leaning it out a hair because you don't need the excessive rich mixture that you'd have with straight gas. All the water should have evaporated a loong time before it gets near the O2 sensor, and has no effect on the reading. With a good efi system, you can protect the engine just like you would with any other critical support sytem by monitoring tank level, pressure, flow, etc. and programming the necessary safeguards if something isn't right.
HaxbySpeed is offline
Old 11-03-2015 | 08:53 AM
  #84
Panther's Avatar
My system also has an activation light (green) and tank level light (red) on the dash.
Panther is offline
Old 11-03-2015 | 09:05 AM
  #85
I was told that while the meth raises the octane so to speak, it also slows the burn down as well, and unless your tune requires it, the gains are minimal. Kind of like putting 93 octane in a stock 454 mag, not gonna do a whole lot. So, it was recommended that in a low boost application, that normally can run fine on 93 octane, pure water, or water with a light mixture of methonal was the way to go. Now, high boost, where say C16 fuel may be needed, than higher concentrations of meth is the way to go . Apparently water itself, does an excellent job of cooling the charge, but doesnt require the fine tuning of fuel ratios, burn speeds, etc.
Just the way it was explained to me.
MILD THUNDER is offline
Old 11-03-2015 | 09:40 AM
  #86
Thanks for the explanation Haxor. I've never used it so I wasn't sure. Makes sense though.
Eddie
Young Performance is offline
Old 11-03-2015 | 09:52 AM
  #87
Long time no see. Good to have you back Alex
Old 11-03-2015 | 10:36 AM
  #88
F-2 Speedy's Avatar
I'm sure he's glad the orange motors are gone
F-2 Speedy is offline
Old 11-03-2015 | 11:17 AM
  #89
Have you seen any benefits of meth injection on low boost applications. I was under the assumption it doesn't work with low boost. To take advantage of the cooling effect you really have to dump some methanol in the motor which leads to an overly rich condition with lower boost levels.
Black Baja is offline
Old 11-03-2015 | 11:26 AM
  #90
CAFE's Avatar
But are they right yet?
CAFE is offline
