Spark plug gap with MSD >
Old 10-28-2015 | 10:04 PM
14 apache's Avatar
Originally Posted by Black Baja
Gap depends on what heat range plug you are using.
What does the gap have to do with heat range?
14 apache is offline
Old 10-28-2015 | 10:30 PM
I know rule of thumb is , a larger gap, can put more strain on the cap, rotor, wires, and coil.
What about running a non resistor style spark plug, or a resistor style oem style plug, say with a 5k ohm internal resistor? Would a resistor style spark plug, combined with some high resistance anti RFI oem style plug wires, also put a big demand on the system?
MILD THUNDER is offline
Old 10-28-2015 | 11:44 PM
BUP
most of all the OEM stock stuff is .45 and .60 Just saying
BUP is offline
Old 10-29-2015 | 04:55 AM
A motor that has higher cylinder pressure produces more heat than a lower cylinder pressure motor. A motor that produce more heat needs a colder spark plug. The reason for the colder plug is to transfer heat out of the combustion chamber into the head and through the cooling system. When you have a motor that has higher cylinder pressure/ heat in the combustion chamber you don't meet a big gapping gap to light the mixture why? Because you have more heat in the chamber. Everything is the opposite with a lower cylinder pressure motor. A hotter plug is used to keep temperature in the chamber and a larger gap to light the mix. The nice thing about plug manufacturers today is they gap the plugs for you based on the heat range of the plug and as long as they aren't damaged during shipping they should be properly gapped from the factory. An NGK -11 from the factory is gapped about .020" what's is a -8 plug gapped to .040"?
Black Baja is offline
Old 10-29-2015 | 06:14 AM
which do you mean, marine or auto
sutphen 30 is offline
Old 10-29-2015 | 06:40 AM
SB
I disagree with the above.
The plug does not impact combustion chamber temps unless you get misfire from too cold of a plug which fouls because it doesn't stay hot enough to keep it's electrode and grand strap clean. Or is too hot where it causes pre-ignition because it 'glows red' igniting the air/fuel mix before the spark occurs. Those are the exceptions.
Heat range is all about the temperature of the plug itself. As noted above, it shouldn't run so cold that deposits and etc don't 'burn off' and stay clean, nor so hot that ot glows red and the a/f mix ignities before the plug sparks.
The amt of surface area of the plug is extremely small compared to the heads combustion chamber surface, the piston top, and the valve heads and thus doesn't really help cool or heat that system. It's all about the plug temp itself.
And thus why CDI systems and multiple spark systems (at low rpms) can be useful...if you need them....a motor that needs a certain temp rage plug for high rpm , high power (ie: high combustion chamber temps) but is too cold for low rpm and/or long idle time use in that motor. What do you do ? Use a multiple spark, high power ignition that will fire the plug that regular power, single spark systems couldn't do to fouling plugs.
Other needs for high power, multiple sparks at lower rpm is non or low quench engines, low swirl, large camshafts with reversion (exhaust gases coming back into comb chamber), low compression, bad comb chamber shape, and etc,etc that can/will create low mixture motion and and/or poor quality a/f mix to ignite. Much more on this but another subject.
Many, many different OE engines in the car world use NGK plugs with 1.1 MM plug gaps. This converts to .043" gap. You cannot say all these different engines (Audi, Toyota, Honda, Hyundai, etc,etc) all have same exact combustion chamber temps and etc as each other. Many different CC motors, NA, turbo, supercharger, and etc,etc......
Plugs use ceramic and other materials to insulate / transfer heat back into the cyl head, More or less of these materials controls how much heat it transfers. This determines it's manufacturer heat range designation so you can compare to other heat ranges of the same manufacturer and model of plug.
SB is offline
Old 10-29-2015 | 07:03 AM
I think you just disagreed with what I posted and then reiterated (long form) what I said...?
I can tell you this from experience. If you have a motor with a ton of cylinder pressure 3000hp worth running a #11 NGK plug gapped at a tight .022 it runs perfect. Open your gap to .035 get ready cause the big boom is coming. So I ask why? Does the gap change the heat range of the plug? I would have to think so...
Old 10-29-2015 | 07:15 AM
no,pressure changes how much the arc will jump to and from.Thats why I love the msd display,back the arc points out an inch and it will jump across it.But in a 1300-1800 nitrous fed small block,go any more than .026" and it won't fire.hummmm,yet in a low comp ratio engine you can have .060"
timing effects the band on the tip,not gap.I've tuned a few nitrous monsters.and this next season,twin turbo humungous block ford.
Old 10-29-2015 | 10:21 AM
14 apache's Avatar
It might go boom because it cross fires under the distributor cap firing the wrong cylinder. Just a thought.
Old 10-29-2015 | 11:32 AM
Pressure does not change how much the arc will jump. Resistance will. Air and fuel create resistance in the atmosphere between the electrode and ground strap. Forced induction creates a denser mixture of air and fuel and creates more resistance across the gap. More compression and other power adders do the same thing. It's not pressure.
horsepower1 is offline
