Procharger fuel system >
Old 10-30-2015 | 02:28 AM
Default Procharger fuel system
Hi guys, can anyone help me out with a diagram of hoe the Procharger carb fuel system is supposed to be? Has pump with boost referenced reg & fittings already plumbed & fuel cooler but no instructions.
Sleek548 is offline
Old 10-30-2015 | 05:44 AM
large fitting @ tank(anti siphoning valve removed) #8or10 line, prefilter, pump, after filter, regulator, split to each side of carb, return from bottom of reg to tank #8, boost reference above carb, recommend a manual fuel pump switch as well, I used a push pull light switch which works awesome and is a great theft device, I do not use water seperater or cooler, too restrictive...Rob
ezstriper is offline
