Aluminum head corrosion
1 year to 15+, all depends on how long it sits in the water, anode protection, good grounds, and how well you flush it. Don't bother with the hard anodizing. I have 4 sets of heads right now that are anodized and needed to be welded on the deck surface.
I have always used cast iron heads and never had a corrosion problem so I know that's a safe bet.would hate to spend all that money on something thats only going to last a few years.most out boards completely drain out when they are not running but there have been problems with yamahas.
If i was in salt, with raw water cooling, iron would be my only choice.
Dart has some nice iron heads, 308, 330, and 345 cc. Engine Quest is casting the old RHS/pro topline iron heads, available in 320 and 360cc runners. Those would be my choices in iron heads.
you need to keep water temps under 140degrees and cooler is better.heads can usually go 4-5yrs if flushed after use and use Dawn dishwashing detergent at the very end.don't know why it works but it does.also use it on cast iron too.
