500 EFI fuel pump oil? >
Old 11-06-2015 | 08:18 PM
VoodooRob's Avatar
Originally Posted by Pwraddr
Curious how often you change your oil.
Most I let it go is 25 hrs, a full season for us. If doing more hrs. I'll change mid-season. Same goes for the drives.
VoodooRob is offline
Old 11-06-2015 | 08:21 PM
VoodooRob's Avatar
Originally Posted by JaayTeee
Some of the very first 500efi's 99-00 didn't have them.
Didn't know the early 500 EFI was set-up like that, good to know for reference. Good catch.
Old 11-06-2015 | 08:43 PM
I will have to look tomorrow when I get to my boat.
1989mach1 is offline
Old 11-07-2015 | 07:46 AM
Originally Posted by VoodooRob
Yes, 500 and 525 EFI. Always change the lube when changing oil, it only takes a few minutes with a mity-vac. As a matter of course I change impeller, impeller housing, and change oil in pump when doing an oil change.
Actually, the earlier 500 efi's don't have this mechanical fuel pump which includes those in my 2000 Formula. My setup has worked fine as I've experienced no vapor locking problems. This is likely due to my boating area not being as hot as inland lake boating.
billpor930 is offline
Old 11-09-2015 | 05:53 PM
I looked at my motors over the weekend and I do not have that kind of pumps.
Old 11-09-2015 | 05:55 PM
Is there a big difference between the two ways?
Old 11-18-2015 | 10:09 PM
Ok, do you have to pull the fuel pump off to change the oil? I have a vac, but can't get anything in the hole to suck it out. Can't believe there's no drain hole.
TROR is offline
Old 11-18-2015 | 11:22 PM
Ok, made me a little tube out of a chunk of steel brake line. Just wondering how y'all do it.
TROR is offline
Old 11-19-2015 | 01:40 AM
You can only get about half the lube out with suction through the fill hole.
Griff is offline
Old 11-19-2015 | 04:59 AM
I pull the whole assembly off every fall during winterizing and it gets a new impeller and new oil. There is always some gas in the oil.
thirdchildhood is offline
