Will low oil hurt 500efi?
I was not aware that the 500efi is known to burn some oil and didn't check like I should have during season. When I just winterized boat I realized that there was only 3.5 quarts, atleast that's what I was able to pull. No alarms ever went off during season and there is no evidence of metal in oil... Is there a good chance I could have damaged internals? The motor is in a fountain fever 29. Thanks
As long as you never lost oil pressure, it would never know the difference. You are good to go.
RuninaFever. I would suggest You remove the oil filter your oil filter and cut it open at the flange, threaded end. Remove the end and pull the paper filter open and look for debris. This is my first step in trouble shooting an engine potential failures. You may call me if you wish. Kyle 29FountainFun. 517-896-4860
Originally Posted by 29 FOUNTAIN FUN
(Post 4373952)
(Post 4373952)
4.5 quarts of oil is a lot to lose/use over a season. Do you have an oil temp gauge?
Originally Posted by Knot 4 Me
(Post 4374536)
You're correct, 3.5 quarts. How many hours did you run this season?
| All times are GMT -5. The time now is 12:09 AM. |
