Merc 420 to 525sc in a Formula 242. >
Old 03-15-2016 | 02:29 PM
  #101
Should be fun in my 242.
79formula is offline
Old 03-15-2016 | 06:23 PM
  #102
What should my timing curve look like? We did not dyno with my dizzy. I was planning on dropping mine in, setting total timing to 34*. I was gonna draw a graph of the timing curve and compare it to the 525sc curve.
Originally Posted by MILD THUNDER
Close to what i was figuring. There may have been a little more torque on the table with a good timing curve.
Thats good numbers for what you have there
Old 04-07-2016 | 07:15 PM
  #103
The motor is in. I started it for a few seconds and killed it. I didn't have water hooked up, my garden hose was frozen. Since these pics i have cleaned up my wiring and hoses. All i have to do is dunk it in the water, set the timing, and go! Cant wait!!!
Old 04-08-2016 | 11:19 AM
  #104
TomZ's Avatar
Really nice looking set-up you've got there!! Can't wait to hear the results.
TZ
TomZ is offline
Old 04-15-2016 | 03:21 PM
  #105
First round of results are in. Full tank of fuel, not fully trimmed out, and tab not all the way up. I brought it up to about 5000rpm, saw 70 on the GPS, and backed off. I think leaving it open and trimming out properly, and pulling my tabs all the way up will get me 75.
Old 04-15-2016 | 03:33 PM
  #106
TomZ's Avatar
That's moving!! How did she feel?!
TomZ is offline
Old 04-15-2016 | 03:36 PM
  #107
Actually it felt glued to the water. I really think if I get the hull loose Ed up with trim, it will really pick up speed.
Old 04-15-2016 | 03:44 PM
  #108
TomZ's Avatar
Very good to hear!
How much boost are you making?
TomZ is offline
Old 04-15-2016 | 03:56 PM
  #109
Made 5lbs. I think having a tight gimbal helps.
Old 04-15-2016 | 04:11 PM
  #110
79,it looks great.you did a top notch job!
mike tkach is offline
