Merc 420 to 525sc in a Formula 242. >
Old 02-12-2016 | 06:33 AM
  #71
SB
Originally Posted by 79formula
Well its been a while since I have updated.
The build is as follows:
Stock forged crank. Reconditioned forged rods with ARP bolts. Melling HV oil pump. TRW 2399 pistons .060 over. The heads I got are stock HP500 Carb heads. They have Manley Severe Duty intakes with inconel exhaust valves. I used a crane 134561 cam with their matching triple springs.
I hope the 'triple springs' was a typo.
Motor looks sharp..
SB is offline
Old 02-12-2016 | 07:02 AM
  #72
Motor looks sharp..
Its has 2 springs and a damper spring. For regular use Crane 99893 is ok. For extended high RPM use Crane recommended 99896 springs. They were $256 vs $89 for the cheap springs. It seems like valvetrain is not the place to try to save money.
79formula is offline
Old 03-14-2016 | 08:02 PM
  #73
Tomorrow is the big day. DYNO TOMORROW!!!!!!!!!
Old 03-14-2016 | 08:41 PM
  #74
I hope that was a typo on those springs.
The 99896 spring is for a hydraulic roller camshaft, and will have way to much pressure.
99896 is 150 psi @ 1.900,and has a rate of 528lbs lbs/in. With your cam, it would have around 450lbs of open pressure. That will kill the cam quickly.
MILD THUNDER is offline
Old 03-14-2016 | 08:55 PM
  #75
Those are the part numbers Crane specifically recomended.
Old 03-14-2016 | 09:01 PM
  #76
My crane catalog shows #99893-16, or 96896-16 for that 134561 camshaft.
Old 03-14-2016 | 09:07 PM
  #77
my catalog
Old 03-14-2016 | 09:15 PM
  #78
Must be some typos.
Irregardless, the 99896 is a heavy spring meant for hydraulic rollers, not flat tappet hydraulics
Old 03-14-2016 | 09:20 PM
  #79
99896 spring specs
Attached Thumbnails Merc 420 to 525sc in a Formula 242.-20160314_211813.jpg   Merc 420 to 525sc in a Formula 242.-20160314_211702.jpg
Old 03-14-2016 | 09:24 PM
  #80
Rookie's Avatar
My solid roller springs had a rate of 551 lb/in.
I recommend not starting that engine tomorrow.
Sorry
Rookie is offline
